Disc brake calipers
Discussion in 'The Garage' started by Muddytazz, Jun 28, 2003.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Is there a difference between the stock front 3/4ton disc calipers on the 2wd vs 4wd rigs?
  2. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Jeff, I believe the space between the pads for the rotor is thicker or larger for the 3/4 ton rotors.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I understand the thickness issue between the 1/2ton and the 3/4ton, but what about using the front calipers off of a 2wd rig? Are they the same ones as the 4wd calipers?
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look up calipers for both rigs at www.autozone.com and see if they take the same part number. /forums/images/graemlins/cool.gif
  5. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Sean took the Raybestos parts book home with him today and is going to look up the part numbers.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Thanks Bill /forums/images/graemlins/thumb.gif
  7. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    they look alike but the difference is where the brake lines attach...that was all i could see... /forums/images/graemlins/confused.gif
