Disc Brake Conversion for 1970 K5
Discussion in '1969-1972 K5 | Suburban | Truck' started by clubba68, Apr 26, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    I am purchasing my first K5 this weekend.
    It is lifted 4" and is running 33's. It has 4 wheel drums non-power, and I have been looking EVERYWHERE for a power disc brake conversion for the front. I have heard the same from everywhere I have gone and called, and that is that no one makes a conversion for the first-gens, at least not a front conversion (only available on 2wd), and I was wondering if anyone has done this swap, and if you just have to use used parts, and if anyone has a step-by-step website, a list of parts, pretty much anything will help.
    Also, my email address is onyx_1@hotmail.com
    Thank you, I really appreciate any and all help.
    -Andrew
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Just swap in a front axle from a '71 or newwer. The '73 up have better ujoints in the front axle. And use the brake booster from a '71-'72. It can be out of a 2 or 4wd truck or blazer. Get the brake lines and prop valve too.
  3. clubba68
    Dec 6, 2002
    1,511
    Would it work to just swap the gear off the axle rather than to swap the whole axle? If the flanges are the same would it be a possible swap?
    Thanks for the help already.
  4. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,294
    Damascus, OR
    Clubba68
    Sent you a pm
  5. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Welcome to CK5 man... check out the PNW forum... you will definitely find some locals to help you out. /forums/images/graemlins/thumb.gif
    As for the D44 conversion, its easier to swap the entire axle than gears and pieces. The D44 from any first gen will golt straight in. I am not 100% certain about a 2nd gen.
    As for parts, check out:
    http://www.offroaddesign.com/
    http://www.a-tron.net/
    http://www.lmctruck.com/ (order a catalog - they have it all)
    http://www.chevyduty.com/ (order a catalog - they have it all)
    Also, check out a place in portland called something like Dan's Classic Chevrolet - tons of stuff there like Chrome front/rear bumpers for $130.00 (cheaper than anywhere else plus shipping)
    There are a bunch more places/catalogs/etc... to get parts from, each place will have some parts cheaper than another so I usually hit 4 or 5 different catalogs/phone calls before making any purchases.
    -Ryan /forums/images/graemlins/k5.gif
  6. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Not really as a '72 and earlier axle has the 260 jeep sized Ujoints in it. Find a '73 or newwer axle either D44 or 10B with the gear ratio that you want to run and just slide one out and the other one in. 4 Ubolts the drag link and the brake lines then the axles outa there and reverse for the new one. Less work than changing all the parts over and stronger too. Then put the rest of the hardware on the truck and you're done. Easy weekend swap withh all the parts there ahead of time.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I do not know about swapping the booster/master but I am sure there is something that will swap directly there.
    On the axle I have heard that the drum outter knuckle has a rotated bolt pattern and so you might have to do a knuckle out swap for the disc brake parts.
    Everything on a 73- D44 will swap directly and if it was up to me I would just drop in a newer D44 and have it done with. You might take this as a good time to swap gear ratios.
    If you swap to a 10Bolt you will need a conversion u-joint at the pinion and new brake flex lines and banjo bolts. Other than that they are a direct swap.
    You will be safe as long as you don't start to mix and match pieces (i.e. spindles and hubs). If you do want to mix and match you will want to look into the differences between 1st design D44's, 2nd design D44's and 10Bolts.
    Edit:
    If you do get a newer axle get the spring plates with it just in case you ever want to put in a sway bar up front. The 73- plates have bolt holes for the sway bar in them.
  8. mcmlxix
    mcmlxix Registered Member
    Nov 28, 2001
    80
    Las Vegas
    I have an 88 K5 blazer donor truck. I can swap both front and rear complete rears? All the perches and brackets bolt up? What about steering? Do I use the 88 steering arm or the 70 steering arm? Can I use the power brake booster from the 88 with the mounting bracket from a 72 that had power brakes?
  9. 6869704x4
    6869704x4 Registered Member
    Aug 1, 2002
    42
    NW Fla
    Not the rear. The spring perchs are different width.
    I did the disc swap on my 70 awhile back. It is way easier to swap the whole axle. I wasnt so lucky. The axle I got had a trashed carrier. If you cant find a whole axle you will need to swap everything from the knuckles out. And get the axle shafts too.
    Brake lines were easy. You can try 73 or so chevy van front lines, they are two feet long.
    Advance auto parts used to sell the booster/master cylinder as a unit, if you cant find one in a yard. I using an adjustable prop valve.
    While you got the knuckles out get the right one machined for xover steering.hehe
