Disc Brakes aren't Brakin!!!!! HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Corey-88K5, Jun 17, 2000.
  1. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Disc Brakes aren\'t Brakin!!!!! HELP
    Well I got the new TSM Disc's in stalled and lines are blead, but now I've got a problem. The caliper pistons only move about 1/4" and then retract. They don't even contact the rotor enough to stop the rear axle when its off the ground and in drive. The main problem seems to be that the pistion doesn't act like the front. When you pump the brakes they just go in and out, not contact the rotor. Does anybody have any suggestions? These are 85 Eldorado calipers. If anybody has any knowledge of the rear system, please let me know. I tried to push the reset button on the proportion valve. I'm not sure if it has to be held in when doing this.
    Thanks ,
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Re: Disc Brakes aren\'t Brakin!!!!! HELP
    I think you may need a bigger master cylinder. I think I've read somewhere (many places actually) that drum-to-disc swaps often need bigger master cyl. due to more fluid required by rear calipers vs. rear wheel cylinders. I could be wrong here, but at least its someplace to start. Hope it helps!
    [​IMG] Semper Maintenance!
  3. Corey-88K5
    720
    The thing is, the pistion isn't "pumping up" so to speak. The front, if you change your pads and press the pistion in to the caliper, you have to hit your brakes a couple times to get the pistion to touch the rotor. The rear's aren't doing that. They just go in and out...
    Corey
    88K5
  4. jarheadk5
    Mar 6, 2000
    4,389
    PA
    I think that might be a master cylinder issue also. I believe disc brakes have a check valve built into the master cyl. that maintains like 10 psi or something in the lines. Again, I could be wrong. I sure hope not though; I hate giving bum scoop!
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>This truly sucks... i just got a dana 60 8 lug rear today and was planning on putting on TSM disks with the Edlo calipers. The guy I bought it from said he has disks on his Dynatrac 60 rear, and the eldo calipers sucked so he got Monte Carlo front calipers and he says they're way better. he said they work better, but they don't have the hook-ups for the cable p-brake, which of course, is illegal not to have in NJ. What master cylinder would be necassary?</font color=blue>
  6. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Re: (Set ER cable first)Disc Brakes aren\'t Brakin!!!!! HELP
    You have to take the play out of the ER cable. The Caddy brakes are not self adjusting-you have to adj. the parking brake so it works first then the piston will push from that point toward the rotor. Apply parking brake and test by turning tire-if tire turns with brake set tighten the cable-on mine I had to rotate the lever arm one complete turn before the piston started touching the rotors.You might even have to remove the lever arm and turn bolt with wrench because of the built in stops on the caliper castings. Oh, one other tip, if you don't have ABS-use Dot 5 fluid ,it's pricey but it keeps the pistons from rusting if you see deep water or mud.
  7. titanic
    Mar 27, 2000
    498
    Re: (Pic)Disc Brakes aren\'t Brakin!!!!! HELP
    picture of a caddy calipers
  8. titanic
    Mar 27, 2000
    498
    pic was too big-I had to reduce-sorry
  9. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    where's the pic?
  10. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    <font color=red>You should swap the master cyl. and also the proportioning valve .</font color=red> [​IMG]
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Titanic's got the answer to your problem. You have to cycle the parking brake lever a few times to get the pads seated against the rotor. Sometimes you have to remove the nut that holds the lever in place, pull the lever forward, then remove the lever and re-index it to take up the slack.
    If you don't get the pads snugged up to the rotor, you'll never get a solid pedal. Been there.... [​IMG]
    http://ThunderTruck.ColoradoK5.com
  12. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Both Titanic and Harry are correct. You have to turn the parking brake lever a couple times to adjust the calipers to the rotor. The p-brake lever acts like a ratchet. I'm using the stock master and pro. valve and have great stopping power.
    Shawn
    87 K5 TSM disks
  13. Corey-88K5
    720
    Cool!
    Thanks guys. I'll give that a try tomorrow. I did mess with the lever a few times, but it didn't make a difference. I'll do it with the intent of getting the damn things to seat.
    Corey
    88K5
  14. Shawn
    1,753
    5
    5280'
    TSM told me that sometimes you just have to keep playing with it until it catches. You want to get it real tight on the rotor.
    Shawn
