Disc Brakes for 14 Bolt SF 6Lug
Discussion in 'The Garage' started by 1972Blazer, Jun 21, 2003.
  1. 1972Blazer
    1972Blazer 1/2 ton status
    Jan 2, 2001
    238
    carlsbad, California 92009
    I know someone makes the disc brake conversions for the 14 SF 6 Lug. Do you just use the 12 Bolt 6 Lug conversion parts? I want to use the same calipers that I have on the front so I have an easy time with brake parts. I found a 1992 14 Bolt SF 6Lug rear with low milage with 4.11 gears and open carrier so it will be easy to install a Detroit. I just need to find out who makes a Disc Brake Kit for this style axle. Thanks for all the help!!!
  2. 1972Blazer
    Jan 2, 2001
    238
    I have searched the archives, sent pm's to members who say they have them and searched all the sponsors who produce brake kits. I seem to be coming up empty handed, any help would be appreciated.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    http://www.tsmmfg.com/
    I think those are the guys that made the kit my friend bought. They are $$$ but great quality.
  4. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    I used the brackets from TSM, rotors for an 88+ 1/2T chev 4xx4, calipers and flex lines for an 84 monte carlo. The whole thing went together pretty easily.
    Aslo, IIRC the detroit for the SF is not like the FF. The SF has a complete replacement carrier, not the drop in style of the FF. Personally, I used a lock rite in mine. Was a simple drop in, has been there for almost 2 yrs now and I have had no problems with it.
  5. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    100% correct. If you want a drop in for this axle use the L-R. The Detroit drop in is the EZ, which is a piece of crap. The FF use the No-Spin.
  6. 1972Blazer
    Jan 2, 2001
    238
    Thanks alot that is great knowledge!
