disc brakes for a 69
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by bub, Apr 21, 2001.
  1. bub
    bub Registered Member
    Apr 21, 2001
    8
    Iceland
    Is there anyone that makes a disc brake conversion for the front axle on a 4X4 ? Will the rotors,calipers,backing plates from a newer Blazer with a Dana 44 fit on 69 spindles? Thanks for any help
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Take everything from the spindles out off of a newer (71+) frontend. Grab the booster, master and proportioning valve too.</font color=blue>
  3. bub
    Apr 21, 2001
    8
    Iceland
    Thanks for the info, I have access to an '87 but the gears are trash or I'd take the whole thing and keep life simple. So when you say from the spindle out does that include the axle stub bolted to it or can I use mine?
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Take the inner shafts too. They have the larger steering u-joint and will pull right out when you remove the spindles.</font color=blue>
  5. bub
    Apr 21, 2001
    8
    Iceland
    Thanks again
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Wouldn't a '87 have a 10 Bolt? Will 10 bolt stuff work on a Dana 44?
    '71 Blazer CST with alot of rust
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The axleshafts wont, but the brakes will. Look for shafts from a 73-up dana 44.</font color=blue>
