disc brakes for a d70 dually rear??
Discussion in 'The Garage' started by supersize75k5, Feb 11, 2007.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    Im looking around and reading and it aprears the dually rear has no brake kits,
    so..
    could I put standard 14 bolt hubs on this and use a 14 bolt kit?
    and why wont kerts or others single rear wheel kits work on a dual wheel 70?
    I would just look , but my 70 is still 2 hours away:D
  2. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    It's the dual wheel that causes problems. If your not going to run dual wheels, Then our d70 kit should work. Haven't set it up but I see no reason it shouldn't.
    There may also be a chance we could set up something a bit more custom.
  3. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    no dual wheel, but I am planning on stock h1 rims;) ;)
  4. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I just picked up a Dually D70 with the 14bolt hubs and it came with Kurts D70 brake brackets, just need some time to get back in the garage to work on it. I would like to see some pics of this setup!
    I have the 3/4ton front rotors, need to find a set of calipers.
    (this is the axle BlueBlazer62 started, sold to Emmet, then I picked it up...)
    http://coloradok5.com/forums/showthread.php?p=1946677
  5. Duallie
    Duallie Newbie
    Jan 14, 2006
    4
    Alaska
    In the mid-90's I disc'd an Eaton in my C30 carhauler. I had a friend turn some 3" spacers to move my rotors inboard far enough to clear the duallie rims and bolted some 3/4 ton 4x4 front backing plates to the axle. My dad disc'd a 70hd by bolting some Dodge? front dual wheel spacers to move the wheels outboard. His truckbed is more than a foot wider than mine, tho.
  6. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Kert, please look into this seriously. I think there are enough of us here on CK5 that want to do this to D70HDs, that it would be profitable. The one stumbling block is that most/all of us are looking for a larger caliper/disc pad than the 3/4 ton caliper.
    Thanks, Jimbo
  7. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    for off road use i cant see why you would need bigger brakes, are all newer chevy dually rears only drum? assume so:confused:
  8. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Just knee jerk reaction, please review for feasibility but could an adapter be machined that would allow you to use the caliper mount, calipers & rotors of a D60 front? Something that bolts to the backing plate mount and then to the caliper mount with the appropriate spacing and what not.
    I dont know how plentiful the caliper mounts are though. :dunno:
  9. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Stock h1's, hmmmm. I'll see what I can come up with.
  10. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    show me the parts and ill show you my wallet;)
    pretty please:D :laugh:
  11. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Read on...
    http://coloradok5.com/forums/showthread.php?t=197410
    :wink1:
  12. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    I always come up with great ideas after somebody else already invented it. It's really frustrating...
