Disc Brakes parts list
Discussion in 'The Garage' started by sandawgk5, Oct 2, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Help me second check my parts list for the parts house. I will still need 2 springs and 2 14MM wrenches to make my levers and I need brackets and hoses also but is the list in the link all that I need? Can I get the brakes lines from the parts house also? Here is the link
    Ira
  2. dremu
    Feb 27, 2000
    15,962
    452
    East of San Francisco
    The link is only good on your computer, sorry :) Screenshot it or copy-n-paste.
    -- A
  3. sandawgk5
    Oct 28, 2003
    6,881
    How bout this:D
    Ira
  4. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    you'll want some 7/16 banjo bolts and 79 chevette lines.. I can get you the part numbers for both if you want..
    you'll also need gear oil, RVT to seal your diff and the metal axle gaskets, and lots of brake cleaner..
  5. sandawgk5
    Oct 28, 2003
    6,881
    Why would I need to seal the diff? I do not plan on pulling the cover just the shafts and then hubs and such. I dont run the axle gaskets just RTV and I have no leaks:D . Forgot about banjo bolts though thanks.
    Ira
  6. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    ha ha, i'm an idoit, I was thinking about when I did mine, I did a lincoln locker at the same time, that way I would only have to buy gear oil once.. You'll still want RVT to coat your metal axle flange gaskets..
    7/16 banjo bolt is HELP 13935
    a spindle nut socket (you can rent them at autozone) makes the job go easier..
    you'll also need a cutting tool to cut your line, and a double flare tool (rented mine at autozone) so you can mate your lines to the rubber chevette lines..
  7. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    2 14mm wrenches?
    what are the 14mm wrenches for? making levers?
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    levers for caddy caliper e brakes
  9. sandawgk5
    Oct 28, 2003
    6,881
    I only run RTV no axle gaskets for me so yes I will need RTV. I will prolly just buy some shorter lines from NAPA so I will not have to cut and flare. I dont do a lot of line work so I dont wanna spend the $13 for the tool:D . Really I am undecided on the lines I am mainly worried about big money items right now. You know funding from "The Bank":D . I run Dana 60 nuts and locks on my 14FF so only need one socket and I already own one.:)
    Ira
  10. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    make sure those caddy calipers are 7/16 before you buy the banjo bolts.. I know my d44 calipers were, but I'm not sure if the caddy calipers would have been 10mm yet or not.
  11. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    D44 calipers would work off an 85 c20 right? I am going to run a line lock.
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    C20s didnt come equipped with Dana 44s ever, much less an 85 since the D44 went away somewhere between 77 and 79. 77 K20 calipers should work.
  13. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    OK my ignorance. What I am trying to get at is any D44 8 lug Caliper should work Right?
  14. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    yep, that's what I used.. asked for a k20 suburban front caliper from 1975... to make sure I ended up with a d44 caliper so I could use the chevette lines which have 7/16 banjo bolts...
    newer corp 10 calipers work too, but you have to use 10mm banjo bolts and find lines that fit accordingly
  15. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    You forgot about the case of beer:D
  16. sandawgk5
    Oct 28, 2003
    6,881
    Nope I just dont order that from Kragen:D . I have come to enjoy the Coors light Cooler Box for working in the garage as I dont have a fridge in mine:( . Not a big fan of the sewers light but it is pints and it comes with its own cooler:D .
    Ira
  17. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Hoses for a '70 Chevelle work great too. They are the 7/16 banjo, the Astro van hoses are 10mm. Both are about 12" long.
  18. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    years to look for?... 2wd or 4wd?
  19. sandawgk5
    Oct 28, 2003
    6,881
    What banjo bolt do caddy calipers use. That is the calipers I am going to use so I need lines that will fit them.
    Ira
  20. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    I ordered the brackets from ruff stuff friday. I hopefully do the conversion in a couple weeks here. Then it is off to Xover steering next.
