Disc conversion fit problem
Discussion in 'The Garage' started by RodsRVF, May 20, 2005.
  1. RodsRVF
    RodsRVF Registered Member
    Mar 16, 2005
    51
    CA
    I am having a problem fitting the caliper on with the pads installed. I don't know if the hubs are on all the way. The gap from the inside of the bracket to inside edge of the rotor it 7/8", is this about right? Look at the picture you can still see shiny metal on the shaft that looks like it was covered I would think by the seal before. I still have not found what the torque spec is on the hub bearing nut too. Right now the space where the outside pad would fit is 3/8" but the pad is 1/2" thick. Anyone got an idea?
    Thanks,
    Rod
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Your right. It doesn't appear to be seating on all the way. Did you replace your bearings? Makes me think the bearings are the wrong I.D. therefore not letting the hub seat as far as it needs to.
  3. RodsRVF
    Mar 16, 2005
    51
    CA
    Yes, new bearings. I got them from my local shop and the service guy in the back press out the old and pressed in the new ones for me so I did not check the numbers to see if they are were the same. Anyone have the part number of the Timken bearing for the inside to check I got the right one?
    Thanks,
    Rod
  4. RodsRVF
    Mar 16, 2005
    51
    CA
    Yes, new bearings. I got them from my local shop and the service guy in the back pressed out the old and pressed in the new ones for me so I did not check the numbers to see if they are were the same. Anyone have the part number of the Timken bearing for the inside to check I got the right one?
    Thanks,
    Rod
  5. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the inner bearing & race might not be all the way seated into the hub.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    X2
    Make sure the bearings are butted up against the c-clips.
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    What he said except I think he means the race should be pushed up against the clip.
  8. RodsRVF
    Mar 16, 2005
    51
    CA
    I just found out the problem. There are 2 types of races for the 14 bolt inner bearing one has a "A" and the other a "S" after the number. I had the wrong one. They are fixing it now and will have it back tomorrow. Just thought I would past it on in case anyone else is going down the same path!
    Rod
