Disc Conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BMR, Dec 10, 2001.
  1. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    I just converted my 14-bolt to a disc and put it under my Blazer; question is that can i use a hard brake line straight up to the caliper, I don't see why not. Or will i have to make it a two piece and buy some steel briaded line?
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    You should at leats use the rubber hose, but the braided works also (i think they just look nice) the reason is the caliper moves back and forth so using the hard line will work for a while, but w/ time it will crack.
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    It's all fun and games till someone loses an eye!
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Where is everyone getting their soft rubber or S.S&gt; lines from that are using the rear brackets from members on the site?
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Somewhere at home I have the part number for the rubber line that I used. I ran hard line out to the end of the axle, then to a bracket that holds the end of the rubber line. For the brackets, I used the front brake line brackets from a '91 Chevy Beretta GT. I cut off the end and shaped it to fit the curve of the axle tube, then welded it to the tube. I'll try to remember to get the part number for the hose tonight. [​IMG] Of course, that's if my CRS doesn't kick in between now and then. [​IMG] [​IMG]
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I got my SS lines from TSM
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    I am using stock front hoses in back
    <font color=green>Oh man, 4:10's are sure better than 3.08's!</font color=green>
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Capt. The hoses I used on mine are Wagner part # F-97661.
  8. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    I got my rear calipers off an Caddy, They were hard lines to the Caliper. They had been on there for 15 years and still worked. But I caved in or used better logic and used TSM's stainless lines also
  9. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I used all stainless from up by the gas tank across the axle and to both calipers. I bought mine from Speedway Motors. They are reasonably priced and were extremely helpful on the phone.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
