disc front/disc rear P-vavle for 14 bolt disco.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beater74, Jan 13, 2003.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    these folks carry what seems to be a GM style p-valve that is made for discs front and discs rear. do you think this could be another solution for our soft pedal problem after converting to rear discs? http://www.inlinetube.com/pro_valves.htm scroll down to the bottom of the page under street rod.
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    The way I solved the soft pedal was to take the little restriction plate out of the PV. This was a great temp fix, but now that is been snowing some what frequently here I have decided to get a disc/disc PV. Just too hard to control the blazer when the rear wheels lock up and send you sideways while going down a hill covered in snow or ice.
  3. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    I just did the rear disc conversion. I retained an unmolested PV/CV and I do not have a soft pedal or premature rear lock up. Fact is it brakes better and more controllably than it did with the 13x3.5" rear drums...
    Maybe I just got lucky?
    Rene
  4. Grim-Reaper
    7,385
    Atlanta
    You talking about that 5 port street rod one?
    Look at the price of that and then look at the price of the WilWood adjustable. /forums/images/graemlins/wink.gif I bet $50 you just answered what one you would go with.
    All that Street rod 5 way does is remove the metering valve in the front circuit and put a adjustable in the rear circuit. Hmmmmm Go look at my disc write up and I tell you how to completly disable the stock CV and then put the $50 wilwood in and saver yourself about $40 (got to buy some line and a couple adaptors) because it's essentialy the same thing. I mounted mine inside so I could adjust it without having to get out to do it. It's sweet because when I'm pulling a trailer I can adjust the bias to the load I have.
    My peddle is fine now and firm. I must have had some air trapped somewhere that worked it's way out. You can barrow my double flare tool if you need it /forums/images/graemlins/smile.gif
  5. Grim-Reaper
    7,385
    Atlanta
    You got lucky but don't be surprised if one doy you end up with rear lock up. My bet is your CV is full of rust and crud from lack of maintance and it's non functional. As long as it stays non functional you will be ok. There have been a few others that were lucky at first then it went to hell.
  6. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Time will tell Grimmy...I post up if it does change though.
    Rene
  7. beater74
    May 29, 2001
    1,749
    atlanta
    gee hmmm grimmy i'll have to think about that one $50 or $100 thats a tough one /forums/images/graemlins/thumb.gif
  8. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Same with me Rene, stock proportioning valve and 1/2 ton master cylender with perfect braking and no rear brake drag. My only difference is that I'm running hydraboost instead of a vacuum booster.
  9. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    I'm running hydro-boost and a one ton master...the vacuum booster hit the round bin when the 6.2 went in./forums/images/graemlins/smile.gif
    Rene
