disc off my 12 bolt and onto my new 14?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990K5, Dec 3, 2001.
  1. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    i just bought a 60/14 combo, i have rear disc now and i want to still use my 79 seville calipers that are bolted to my 12 bolt (e-brakes are hooked up and they work fine) is this possible? what brackets and disc do i use? are 8-lug disc too thick for my seville calipers? thx j.c.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, the rotors for the 14-bolt disc brake setup are too thick for the Seville calipers. [​IMG] Maybe if you used half-worn brake pads you could get them to fit.... [​IMG]
  3. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    then what calipers do you ues that have e-brakes?
  4. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    El Dorado calipers.
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, Eldorado rear calipers. 76 to 78 models ONLY, if I recall correctly. They are rare and expensive. [​IMG]
  6. ricka
    ricka Registered Member
    Nov 24, 2001
    40
    Beaverton, Oregon
    Would you mind telling me about your 12-bolt disc brake set-up? I'd
    like to know if you got a kit or did it yourself, what parts you used,
    what they came off of, how you hooked the emergency brake up, etc.
    Did you notice an improvement in stopping power after you did it?
    I have a 12-bolt with Warn's full floater kit, so this might complicate
    things, but it might make it easier too...
    Rick Anderson (rick.d.anderson@tektronix.com)
    Tektronix, Inc. Beaverton, OR 503-627-2630
  7. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    what is the thickness of your current rotor
    i believe ford sourced 8 lug rotors can be found as thin as 1"
    my dodge rotors are 1.5"
    the chevs are ? what ? 1.3"
  8. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    my calipers are off a 79 seville, disc off a 92 1/2ton 4x4 chevy front, made my own brackets, tossed the fact. a.b.s., no proportioning valve, stops great!
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Doesn't sound like you're running a 14-bolt full floater in the rear.
