Disconnect speedometer cable Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MTPockets, Feb 28, 2002.
  1. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    my speedo gear is stripped and i hardly drive on the street, so i replaced my speedo with a monster tach.
    Q: if i pull the speedo cable out of the t-case am i going to lose all the gear oil?
    MTPockets
    MAD MAX: http://community.webshots.com/user/mtpockets35
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I'm not too sure on a 4wd...my 2wd leaked pretty bad when my cable was loose. I would cut the cable end off to get the nut, then put something like a nickle(or whatever size it takes) with a little gasket sealer inside the nut and screw it back on...
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/goose>www.jmartin.net/goose</a>
  3. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Mine right now has no speedo cable in it and it is a NP203. Im not seeing any noticeable oil at all.
    </font color=blue>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
    "If First you don't succeed, Destroy all attempts you've tried"
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    nope.
    i havent had the cable in for 2 years (keeps the mileage down, insurance, stufflike that) i have it zip tied to the frame, i had it outof both a 203 and now 205. theres no oil to come out, its a sealed section nothing goes in either
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    There most definately is oil where the speedo cable goes in. You would have burnt up gears without oil lubing them. Anytime there are two items meshing with each other you need oil to lubricate them. Oil will not leak out if you remove the cable from the adapter. The gear that the cable goes into is a blind hole, meaning that it doesn't go through to the inside.
    1989 blazer, 383 stroker, D44 / 14FF, 4.56, locked, 35 BFG mud
    Scott
