disconnected my swaybar and DANG!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, May 26, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    what a difference!! i probably got 50-75% more front end flex now! and the ride on the street is better too! it does roll a little more in the turns but it's not scary. will the ORD discos give me the same feel on the street as completely removing it? check it out <a target="_blank" href=http://coloradok5.com/gallery/albun07>http://coloradok5.com/gallery/albun07</a> the album titled no sway bar.
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    The ORD disco's will do the same for you. They're a good idea if you tow or whatever with your 'Burb.
    Rene
  3. muddysub
    Jun 23, 2001
    10,451
    489
    thanks
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    They do help..But it is not the same with it disconnected completly.. Also if you brake hard with them disconnected..you get a lot of movemant...But the ORD disconnects are worth the money...Dan
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    What I meant was if the sway bar was disconnected by unbolting it would be the same as if you disconnected it with the ORD set-up. Same results...the big bonus is the sway bar connected with the ORD set-up is now 'corrected' for the lift and won't bind as much.
    Rene
  6. muddysub
    Jun 23, 2001
    10,451
    489
    less binding means a smoother ride? right?
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Better ride and better flex even when the sway bar is connected with the ORD disco's. I chucked my swaybar completely, mostly because the Rancho's I have are pretty stiff. I have next to no body roll or front end dive even with no sway bar. With softer front springs I'd run the disco's...
    Rene
  8. muddysub
    Jun 23, 2001
    10,451
    489
    my pro-comps are the same as the 4" ranchos, part # and all. (rancho makes pro-comp) so i know what you mean by stiff.
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmm.....tRusty....You run the same springs as I do with no sway bar? Not really any different? Hmm.....Maybe I'll go out there and chuck mine as well....There's almost no bushings left anymore anyways...../forums/images/icons/crazy.gif
  10. muddysub
    Jun 23, 2001
    10,451
    489
    do it man it's not as bad as you're expecting!! /forums/images/icons/shocked.gif
  11. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Truth be told I've towed our 21 foot trailer without my swaybar a few times. I'd pitch it in the dumpster but I plan on going with much softer front springs one day.
    With the rancho's I have I found it actually rides better and handles the same without my sway bar...
    Rene
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Yessir. Soooo true. Just went out and unbolted mine....I like the way it drives and handles better without it. Seems alittle more....forgiving. lol, Just another part to add to the growing pile in the garage. /forums/images/icons/crazy.gif
  13. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Swaybars are highly over rated!!! I chucked mine long ago!! I have a 3500 pound 9.5' cabover Lance camper on my dually crewcab (10" lift, 42" Swampers) and tow an 8500 pound 28' boat with no trouble. I do not miss the worthless swaybar!!! Took em off the other two Chevy 4x4s I own also!!
  14. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I'll disconnect mine when I do my new lift.
  15. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I took mine off to replace the bushings, and as an experiment left it off. That was about two months ago. With the one ton springs out back and the TC HD's up front I have some body roll if I push it (on the street and when desert running), but man is there a lot of articulation. I plan on putting it back on when I get real bored though. So probably some time by NEXT summer!
  16. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I have the disconnects and ended up just leaving them disconnected. However when the swaybar is disconnected I get some serious death wobble, so lately I have been reconnecting it after wheeling.
  17. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    how would it be if you disconected it from a stock k5?..sounds cool was wondering if i should do it to mine..i kinda wanted to wait after i get my 4" lift in...i was thinking of going with rough country for a lift? comes with the heckorthorn 8000 or 9000 shocks or something like that i think...?
    Bryan-later
  18. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    Bryan-later
  19. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I had the sway bar disconnects on the K5 while it was stock, the only issue I ran into was while the sway bar was connected, even during street use, the sway bar would hit the bracket thats supposed to hold the sway bar out of the way. I bent my bracket like crazy and had to hammer it flat again. Other then that I didn't have any issues before I put the lift on.
  20. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    really..well i think im just going to disconnect it sometime and see what its really like..put it on some ramps or something and drive it around a little like that..if i like it ill just take the whole darn thing of! lol..
    Bryan-later
