disconnecting ABS how to please?
Discussion in 'The Garage' started by tweaker, Feb 2, 2005.
  1. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    I have a 88 with 18" lift and no use for the stock ABS. so how do i disable it? also I've been reading on how to bleed the brakes and I'd prefer lay-man's terminology. I've heard gravity bleeding and i don't know if it works for this setup ie. crappy ABS.
    thanks
    Dillon Carson
  2. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    take off fuse panel and remove the fuse in the abs section. then remove any power to the pump that might go to batt.:D
  3. tweaker
    Mar 21, 2004
    263
    what about switching to 4 wheel disks. anyone got recomendations on what to do for that as well(you know for the master cylinder, valves, and such).
  4. sweetk30
    Nov 1, 2004
    25,542
    539
    now now you might get what you need by doing a serch and or look in the tech section and product section on the main page.
  5. tweaker
    Mar 21, 2004
    263
    what terms should i use for searching?please?
  6. sweetk30
    Nov 1, 2004
    25,542
    539
    disk brake swap or 14 bolt or brake swap.
    and what axle you runing
  7. tweaker
    Mar 21, 2004
    263
    thanks
