Discount Power steering cooler
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ponderingjunkman, Dec 18, 2001.
  1. ponderingjunkman
    ponderingjunkman Registered Member
    Dec 6, 2001
    14
    Cairo, NY
    I plan to use a hydro boost on my truck- as well as a diesel radiator. With the manual trans, the cooler for the auto in the donor radiator will be simply along for the ride. So the question is: Will the cooler in the 4 row diesel radiator withstand the pressure of the return(low pressure side) of the power steering-brake assist line? Will this be an effective cooler? the radiator trans cooler will be doing nothing anyway...maybe I am pondering too much. Anyway, thanks for letting me join this very cool list!! Yes, my truck is a heep, but it (hopefully) will prove worthy with the general's best drivetrain in it!!
    No Replacement for Displacement
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    That is a good idea - hope you get a 'yes' on that.
    I was thinking of upgrading to a heavier duty tranny cooler and just bypass the radiator so I could potentially do your idea also (if that is also ok to do).
    Dave
    Horn Broken... Watch For Finger.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  3. lasvegas
    lasvegas 1/2 ton status
    Feb 27, 2001
    122
    Las Vegas, Nevada
    I bought a new four row radiator from radiators.com and the guy at the local warehouse told me that the he thought the power steering return line was too high of pressure for the cooler. However, if anyone knows the pressure of the trans lines versus the pressure in the return line on power steering pump, it would be easy to figure out. I ended up just splicing into my return line on the power steering pump and plumbing the line through a perma cool trans cooler. But I have not started it up yet (will this weekend). This was done as part of swapping in the ZZ4. So, I will let you know if the perma cool cooler holds or not!!!
  4. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    I used on old tranny cooler for my power steering cooler and it worked great.Only problem I had was when I added hydraulic assist it wouldnt bleed right but I think it was because I didnt have an added resevoir for the pump
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    it is a great idea,
    the presure will be very low on the return side as there is relatively unobstructed flow
    unobstructed flow=no pressure
    restriction causes pressure
    the return line from the factory uses a simple hose clamp
    does anyone know the size and thread of the rad trans cooler fittings? normal pipe thread or ?
    how about the PS box and pump?
    I am upgrading to real hydraulic fittings and doing the cooling through the rad thing
  6. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    The cooler fittings are usually inverted flare. You may have to use two fittings, I couldn't find inverted flare x barb fittings.
    Never said I could spell!
    '70 K-20 San Diego, CA
  7. michaelm
    Feb 2, 2001
    872
    I am going to try and find a couple of 90deg adapter fittings and use -6 hydraulic line for the entire PS system.
    overkill but I think it will look tough
  8. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    mj, did you ever get the ps lines run through the radiator, and if so, how did it work out? I'm plumbing mine tonight, but I'm using the integral oil cooler in the diesel radiator. I'm using crimp-fitting hydraulic lines (JIC) from the box to the ram, stock pressure hoses (2, pump to hydroboost and hydroboost to box), and rubber transmission line/factory oil cooler hard line on the return.
    As for the fittings: tranny is inverted flare (fuel line), ~80 and newer steering hoses are metric o-ring (I think older is inverted flare, not sure). You can buy adapters from metric o-ring to JIC at some speed shops, it is also a standard Dana Weatherhead fitting, any good hydraulic shop should be able to order it.
    Pete
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    didnt finish that
    Our fittings cupboard didnt have the correct ones
    I have the -6 fitings for the hose but have not gone to a better stocked hydraulic shop to find the correct thread pitch
    assuming automotive vs industrial sizing the problem
  10. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Anyone finished their project yet?
