Disk brake bracket/spindle space question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Jan 18, 2002.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    The problem is, how does the spindle stay on the axle? When I install the brackets with the spacers there is a 1/2" gap around the spindle. Is this bracket supposed to press itself against the spindle to hold it there?
    Bo
    If it breaks, it wasn't good enough!
    <a target="_blank" href=http://communities.msn.com/Liberation>http://communities.msn.com/Liberation</a>
    &lt;a target="_blank" href=http://coloradok5.com/gallery/liberator&gt;http://coloradok5.com/gallery/liberator&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by Liberator on 01/18/02 11:29 AM.</FONT></P>
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Need help installing misfit\'s disk brakes!!! May have a problem!
    The spindle is welded to the housing tubes.
    That "space" you see after bolting the spacers and brackets to the flange is NORMAL. Nothing to worry about there. That's as far as the plate goes to sit on that flange.
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. Liberator
    Jul 16, 2001
    276
    Thank you very much! This is turning out the be easier than I thought!
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Whew, I read this post at work and couldnt reply till I got home for lunch...I was going to say, if your spindle came off..you have a big problem. Hope it goes smooth.
    Brent
  5. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    who has the rear disk brake brackets for the 14ff and how much money are we talking?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Misfit...$65.
    45acp...$100.
    DERBINATOR...$100.
    Off Road Unlimited...$900.
    TSM...$300.
    Those are the major ones that I know of.
