disk brake conversion (banjo bolt)?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84Sierra, Feb 16, 2002.
  1. 84Sierra
    84Sierra Registered Member
    Jun 1, 2001
    43
    Cleveland
    I'm having a hard time finding the banjo bolts for the D44 calipers for the disk brake conversion. I got the brackets from misfit and I have everything else. I just can't find the stuid bolts. AutoZone doesn't carry them and Advanced Autoparts only has them for the 10 bolt calipers. I tried two different Adv. auto parts and then I checked their website and it says they don't carry them. Where is everyone else getting the banjo bolts for the conversion?
  2. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    AUTOZONE DOES HAVE THEM I WILL TRY AND GET THE PART NUMBER. WHAT I DID IS THEY HAVE A BOX OF THEM BEHIND THE COUNTER SO YOU MATCH WHAT YOU NEED.
    I'AM NOT YELLING I JUST HATE THAT DAMM SHIFT BUTTON
  3. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    I bet a local brake shop could tell you where to get them.
    If you knew the truth, you too would be against marijuana prohibition!
    Blue '74Blazer Topless W/ 35 BFG Muds1" Body Lift W/ Energy Susp. Bushings
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    This is also what i had to do. asked the guy for banjo bolts he said "we don't have those" i said "let me behind the counter and i will find them for you" guess what i found. a box full of different size banjo bolts. i guess it's pretty bad whaen someone that dosn't work at a place knows it better than the workers.
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    83 Chevy, 350, sm465, lincoln locked14ff, dana 60,4.56's, (sometime soon flatbed,and 39.5" TSL's)
