disk brake conversions
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ccchauser70k5, Nov 4, 2001.
  1. ccchauser70k5
    ccchauser70k5 Registered Member
    Nov 4, 2001
    41
    Bristol Wi.
    I have a 70 k5 with 6 lug bolt pattern that I would like to convert to disk brakes. Should I find a kit or can I put one together my self.
    What do you all think?
    1970 k5 4x4 camping family
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    can swap a later model front end under it, or if you have an open knuckle axle now you could just swap disc knuckles onto it form a later axle
    good luck
    '72 K-5 4x4, CST, 3.07, 4 speed, NP 205, 31' x 10.5", converting to 2wd and pickup body(I did not want to do this- rust made me do it)
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Swap in a later model front end from a 73-91. You get disks and bigger steering u-joints. Make sure you get the master and proportioning valve too
  4. ccchauser70k5
    Nov 4, 2001
    41
    Bristol Wi.
    thanks for the input. I see what I can do.
  5. ccchauser70k5
    Nov 4, 2001
    41
    Bristol Wi.
    thanks
