Disk brake rotors for rear...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, Apr 4, 2002.
  1. dyeager535
    26,979
    Anyone happen to know of any 6 lug rotors that will fit the rear, that are 1" thick? The 79-85 El Dorado calipers look easy to adapt, and the bolt pattern for the backing plate/caliper bracket APPEARS to be the same flange bolt pattern as the trucks (meaning the whole assembly might bolt on "easily") ... if I can find rotors that are six lug, 1" thick, with same bolt pattern, I can at least mock them up, to see if its worth it over the 76-78 Calipers which are pricier and rarer.
    Bigger is better, I know, but $40 for the entire setup I couldn't pass up. Definitely going to use them on my car, but if the same setup will work for the truck, it will simplify things.
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i think TSM uses "machined" 4x4 front rotors. youhave to machine the inside of the rotor so it will fit over the rear axle.
    ARQ.
  3. dyeager535
    26,979
    Yeah but the fronts are (IIRC) 1.25" and only the 76-78 El Dorado calipers were big enough to use in that application. If I can find thinner six lug rotors, I can use the easier to find (albeit smaller) 79-85 calipers. I'm sure they aren't as good to use as the 76-78's, but with a relatively light truck and relatively small tires (compared to others on here lol) I think they'd work ok.
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    What about toyota rotors?
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Also the newer GM trucks have disc brakes in the rear, and are all 6 lug. I think Nissans and Toyotas are too.
  6. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Use the front rotors off a 88-95 pickup 1/2 ton 4x4.
  7. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    88 - newer 1/2 ton 4x4 front rotors .. there are 2 sizes avail .. 1" and 1.25" .. I used the 1" and instead of trying to machine the inside of the rotor i turned down the end of the axle flange .. I only needed to take off about 1/16" to get then to clear.
  8. dyeager535
    26,979
    Hmm. I'll have to take the Cadillac one with me to the local auto parts store and see how similar they are. I would just hope all the dimensions are the same or similar. Thanks for the tip!
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    no kidding
    why make the service item custom one off
  10. Scooter
    Nov 18, 2000
    551
    Grandview, Mo.
    that was my thought on it too. didnt make sense to do it any other way.
