disk brake upgrade?
Discussion in 'Tow & Trailer' started by Steve_87K5, Feb 26, 2004.
  1. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I've got twin Dexter 5600 lb axles w/12" x 2.5" electric drums (trailer tagged as 9800 lbs GVW). I service the brakes a lot but there is always some problem.
    I'll make the brackets, add the calipers and do whatever machining is needed to mount rotors.
    But its the electric to hydraulic servo I'm pondering.
    (assume keeping the electronic brake controller now in use)
    Thought experiment: use a common vacuum over hydraulic servo. Add a 12VDC vacuum pump to provide vac source. Find a PWM vacuum valve, which would likely be an off the shelf emissions part. Adapt the PWM output from the electronic brake controller, to the vacuum valve, so the valve sees a proper signal.
    For emergency stop, have a 2nd dedicated hydraulic master cyl with a big pinned spring and a pullout wire on the pin.
    Ideas?????
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Not necessary to do all that. I think Northern has a kit to convert them over to disc fairly reasonably. I will see if I can find it and post a link this evening when I get time.
    John
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Here's an actuator for disc brakes. It's the only one I could find that ran off of the electric signal from the truck.
    BIGJ
  4. Steve_87K5
    May 26, 2000
    521
    central NC
    thanks for the link and reference to Northern Tool. I was in their Raleigh store and looked at the disk kit. That BrakeRite electric-hydraulic is exactly what I need. I'd like to see one. The controller plus 4 disks would come to $1100 without the plumbing. ouch.
  5. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Why not put a surge tongue with those disks? I've been thinking of doing it to my camper. Mine only weighs 5K though.
