disk brakes
Discussion in 'The Garage' started by fink, Jul 9, 2004.
  1. fink
    fink Registered Member
    Mar 11, 2001
    86
    Just converted my 71 k-5 to one ton, w/ 4 wheel disk brakes, I did a search but didnt find a definate answer. I eleminated the stock proportioning valve and plumbed in a wilwood prop. valve for the rear. Before I go further do I need a 4 wheel disk master cyl. (for the proper piston bore)?? much obliged in advance /forums/images/graemlins/1zhelp.gif
  2. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    You should be ok. Just watch your fluid level, as disc brakes take more fluid, and as your rear brakes wear, your fluid level will drop. The stock brake master cylinder doesn't have enough fluid capasity for disc brakes. Good luck!!
