disk brakes.
Discussion in 'The Garage' started by eightyone, Mar 13, 2006.
  1. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    is a rear disk swap in a 940 2500 pretty much the same as a disk swap in an older vehicle with a 14bff? and is there an advantage when towing? my drums arent really doing the trick. i have hydroboost if that matters. thanks.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I don't think that is exactly the same. As in it would require a different kit.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    most likely a different kit like already stated... however you will LOVE IT!!!!!
    I would tromp my brakes and the back would just LOCK!!! now I actually stop... :haha:
  4. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I am thinking of making my rear drums disk brakes. What kit would I use????? Would the truck still be legal?
    Adam
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    well legal.... I went with 1976-1978 cadillac eldorado calipers.. and I have an ebrake... weather it works or not is another story... but inspection verifies that it is there....
    what kit to use...
    cant help you there.. I used a kit from az-kickin.com and loved it....
  6. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Do you have rear ABS? If so, then you may have to bypass that system. Also, you need a different bracket. The common 14BFF disc conversion bracket will not work.
    We make the bracket set for the newer 14BFF pop-off drum style axles. It uses the same rotor and caliper as the old style, but the bracket set is different. PM me if you are interested.
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Listen to this guy.
  8. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Nope I don't have ABS. This is a 1986 K5 Blazer with the stock rear end.
    Adam
  9. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    For your rig, you need a kit like this http://www.blackwidowperformance.com/10_bolt_brakes.html
    The rotors slide over the wheel studs, not mounted behind like most other kits use. Much easier on the install.
