Dissapearing Trans Fluid
Discussion in 'The Garage' started by Guss, Nov 6, 2006.
  1. Guss
    Guss Registered Member
    Feb 6, 2005
    78
    houston
    OK, I put a used 700r4 in my 90blaz. about 9 months ago. now the fluid came up missing out of it. no leaks,just gone? now im very confused i put new fluid in and now all the shift points are off. need a tranny guru to help
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Check your t-case to see if it's overfilled.... Could be losing it out the back seal...
    shift points are controlled by your TV cable.....
  3. Guss
    Feb 6, 2005
    78
    houston
    the tv cable doesnt appear to out of adjustment. ill reset it and see if that works. as far as rear seal didnt even cross my mind thanks.
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,025
    852
    Pinckney, MI
    If your shift points are off your tv cable needs to be adjusted.
  5. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    if its not going outthe rear seal, check you modulator their diaphram will bust or crack and it will allow the engine vacuum suck trans fluid up that line and burn it, therefor looking like its disappearing, but it would cause it to smoke white smoke ,depending how bad the diaphram is busted depending on how much smoke you get.
  6. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    700R4 doesn't have a modulator... that's TH350 or 400... probaobly rear seal... it's a common problem.:laugh:
  7. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    agreed... check the T-case :( :(
  8. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    hmmmm
    i did not know that, thank you teacher:bow:
  9. Guss
    Feb 6, 2005
    78
    houston
    thanks guys as you said the problem with shift timming was tv cable have to readjust every two days or so, so ill replace payday the fliud isnt pulling the diapearing act now put prob. 400 miles on since refill still at same level so im scare to check transfercase. the fluid does smell burnt already is that from the tv cable comming undone every once in a while
  10. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Takes 2 minuets to check the fluid in the xfer case. Just put a catch pan under the back of the case, remove the top fill nut (make sure your not lying directly underneth it) and if excess comes out, its leaking thru the seal. I drain the excess from mine every 2nd oil change and add as needed to the trans. If your trans fluid is brown and smells burned, I'd flush it and hope its not too late :crazy:
