Dist. module
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KILLERK5, Aug 17, 2002.
  1. KILLERK5
    KILLERK5 1/2 ton status
    Oct 19, 2000
    108
    Aurora, Colorado
    I was told to take the cap and rotor off of the distrubutor to get to the module, then unplug and un-bolt the black box that is inside. There isn't really anything inside the cap. Is the dist module the litte thing that the two plugs go into? There isn't anything else on the distributor, so im guessing that this is it, but I wan't to be sure!!
    Thanks!!!
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That's it! /forums/images/icons/cool.gif The new one will come with a little capsule of grease. You MUST smear the grease on the back of the new module before you install it, or it will burn itself up in a very short time. It needs to be able to transfer the heat it generates to the plate that's under it. The grease is a thermal conductor that helps with the heat transfer.
