Distance between frame rails
Discussion in 'The Garage' started by cj7jeep81, Jun 10, 2004.
  1. cj7jeep81
    cj7jeep81 1/2 ton status
    Feb 17, 2003
    110
    Indiana
    I'm in the process of replacing the bed floor in my '78 K10, and one of the rear crossmembers needs to be replaced (looks like the previous owner tried to tow a tank or something with it). It is pulled out and pretty messed up.
    I measured the distance from the outside of one rail to the outside of the other near the cab and it is 34". At the back, it is about 33 1/4".
    Do the frame rails get closer together towards the back, or is it messed up?
    Thanks for any help! /forums/images/graemlins/truck.gif
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    all 3 of mine measured at 34.25.
    muddytazz just ran out and measured his at 34" (thanks for doing so jeff /forums/images/graemlins/tongue.gif )
  3. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    Thanks. I'll replace it and make sure its the same distance apart as everywhere else.
  4. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    I got the crossmember of, and attempted to spread the frame rails back out with a highlift jack. I managed to open it up another 1/2" or so, but I'm not confident on getting it to open the rest of the difference. Do you think the difference will cause any problems? Its been off by the 3/4 of an inch for a long time, with no apparent issues, but since I'm finally rebuilding it, I want to do it right.
  5. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    know anybody with a winch and a telephone pole???? /forums/images/graemlins/thinking.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif thats how I straightened the frame on wrecked pickemup truck
  6. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    I don't think I'll go quite that far. I'm not too worried about it (since it isn't much, and hasn't caused any problems I'm aware of). I figure if I can get it within 1/4-1/2 inch, it should be close enough.
  7. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    [/ QUOTE ] /forums/images/graemlins/thumb.gifmeasured my '84k10 the other day for a reese hitch(34"_also,try heating the frame with a torch and using a bottle jack and two chunks of 4x4 between the frame rails.kinda like 'dis...[|-|](brackets are framerails,vertical lines are 4x4's,horizontal line is bottle jack)if you go too far,a little more heat and a ratchet strap will bring it back together.
  8. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    Thanks for the replies. Next time I get a chance to work on it, I'll try to get it as close as I can.
