Distilled v. Deionized H20
Discussion in 'The Garage' started by opfor2, Nov 28, 2005.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    which is better for the cooling system, deionized or distilled water? which would be considered "Pure" water ?
  2. BROKEN-ONE
    BROKEN-ONE Registered Member
    Sep 15, 2005
    78
    kansas
    distilled water
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Deionized is better for aluminium. It is what I run. I also run the Honda coolant. It is blue. It is deionized.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Both are technically pure however distilled is just fine for your radiator. The thinking behind this is it has been boiled which leaves all minerals and particulate behind, the steam is condensed into water which is "pure" this will prevent deposits from the water be left behind in your coolant system. Deionized water is the same thing that is passed through an ion filter bed which then makes the water 100% pure so pure it will not boil at the standard 212 F and so pure you can spray it on electrical equipment and not be shocked it is how they was highpower lines to prevent hot spots from dirt build up. There is no need for the extra cost of DI water. Granted I am in the military but our DI water costs us about $10 per gallon.
    Ira
  5. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    If it were me, I'd use distilled water because deionized water is pretty hard to come by in Murphy, NC. But both are considered to be 'pure' water.
  6. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    Hey all, thanks for all your help. Looks like distilled H20 it will be.
    Dan..
