distributer ground?
Discussion in 'The Garage' started by bryguy00b, Feb 12, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    wear is it? thats the last thing i can think of as to why im not getting spark..
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    The distributor housing is the ground. Did you replace the whole distributor? If so check the coil. I just got mine back together and it had a defective coil.
    Bill
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there is a power wire that might not be plugged in. on the plugins on the cap, its the back on closest to the driver. check to see if you have voltage when the key is on /forums/images/graemlins/waytogo.gif
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea..12 volts to the coil right? on mine its a red wire..plugs in wear it says "batt"..yea i get 12 V there if thats what ur talking about.. then behind it theres that big plug that plugs in..
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what came with the new distributor that you bought?
    did you replace the coil?
    do you have the button under the coil?
    replace the module?
    rotor good?
    if you were closer id let you borrow my distributor that has new everything to see if the dis is the prob /forums/images/graemlins/dunno.gif
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    no i havnt even bought one yet but im about to..i swaped the cap/coil and roter from my dads truck on there, modual was tested..and so was the pick up...both tested fine...and i had 2 different moduals on there to..nothins workin and yea the button is on there..
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if everything is hooked up and tested fine then /forums/images/graemlins/dunno.gif
    take the entire distributor out of your dads truck and try it, there might be something we both are missing.
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well i dont wana mess wiht hsi truck...its runnin good and i dont wana F with it /forums/images/graemlins/rotfl.gif maybe ill take the one from my blazer...or ill just go buy a new one..
  9. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i have seen the testers pass a bad ignition module at part stores.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Is this your 86? If so, it probably has ESC. Your best bet in this case is going to be to remove all that worthless crap and put a regular 4 pin HEI in it. ESC is a worthless system that GM installed on 305s that consists of a knock sensor, a little computer module, and a 5 pin distributor module and extra plug.
    I had it short out on my 84 years ago and it drove me nuts trying to figure out WTF was going on. I ended up getting another distributor, not knowing even what ESC was, but the new one didn't have a hookup for it. Turned out that the ESC was the problem all along.
    In short, get yourself a regular distributor. When I was 16, I'd payed $35 for one from a junkyard. It seemed a little bit expensive for used equipment, but it got me going, which worked great for me.
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yes the 86..im not sure if this has a knock sensor or not..it did have a 305 origionally but was swapped out for a 350
    and yea that guy at autozone seemed a little doofy so...i dunno..ill take the one form my dads truck and see what she does..
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I know it had a 305 originally. Every 82-86 gasolone powered 1/2 ton Chevy truck had a 305 from the factory. /forums/images/graemlins/thumb.gif
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i have too. left me stuck on the side of the road more than once.
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i second getting rid of the ESC.
  15. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    huh...really..knew fact! /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif
