Distributor cap and rotor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Itali83, Oct 11, 2001.
  1. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I think it is time for a cap and rotor. I haven't done it yet since I've had the truck, and I'ld like to. How much am I looking to spend, how hard is it to do, and should I buy a GM one or just go to Napa?? Thanks a ton guys.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
    <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a>
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    The GM or NAPA parts will work fine, NAPA being the cheaper (price-wise) of the two. Expect to pay around $20-$30, I'm thinking. It's easy to do, just remember the firing order! My Naval Fleet
  3. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Changing the cap and rotor will take you about 20 min. I would recomend like Burbinator, to replace wires and plugs.
    It wont hurt. Be sure to get Di Electric lube (sp?)
    It gives it a better connection so that the metal wont carode(sp?)
    Take your time and again have FUN!
    This is what its all about.
    Later KEN
    DANGIT it's not a bronco!
  4. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Get a cap with the brass contacts, it will last longer with less build up.
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  5. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    ok thanks guys, the plugs and 8mm wires have less that 15K on them, so I don't need to do those. I just need the cap and rotor, so get the electrical grease, and get the cap with brass electodes. anything else?? Thanks guys!!!!!!!!!!
    Ben 87 Jimmy
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Get a can of contact cleaner and give the advance a cleaning while you're in there - made quite a difference on mine.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    Burbinator, I know that it a drawing, but it shows a distributor that has the coil built in, I don't have the built in coil, does that make a difference??? Thanks
    Ben 87 jimmy
