Distributor Drive Gear ??
Discussion in 'The Garage' started by 70jimmy, Sep 14, 2006.
  1. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    I am putting a Competition Cams 4 X 4 extrem cam in my new to me 350, also having heads rebuilt, new lifters and in the info with the cam they recommend putting a new distributor drive gear in. I have found Bronze, iron, and carbon ultra poly composite, also iron. Any opinion on what is better.
    Also it appears that you can get them in either a .491 shaft or .500. Is .491 stock size for GM HEI???????:1zhelp:
  2. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Ask Comp. They'll tell you witch gear to run on their cam.
  3. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    Definately ask the manufacturer. Regular flat tappet cams usually take an iron gear. A lot of roller cams need a bronze gear. You need to get the correct one for your application.
  4. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    .491 should be the correct size for a GM HEI. 0.500 is for a MSD or Mallory aftermarket type. If you have a stock type cam with a cast iron gear, you should not need a bronze gear or plastic. The bronze are for billet cams that do not have the cast iron gear pressed on.
  5. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Just get the GM gear from dealer or GMpartsdirect(iron).
