Distributor Help
Discussion in 'The Garage' started by Blazer1AB, Sep 1, 2005.
  1. Blazer1AB
    Blazer1AB Registered Member
    Sep 1, 2005
    29
    KC
    Hi, Im new here and this is my first post, but I have a question I need some help with. I wont go into a lot of detail right now, but my main question is how would you replace the distributor on an 83 Blazer. Its the HEI- I know how to get it out and all that, but I'm just not sure what to do to put it in correctly. Do I just mark the position of the rotor and vacuum cannister and line the marks up the new distributor? Please help, this has to do with me getting my first blazer.
  2. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    Its a biotch, but someone who knows will chime in. ;)
  3. Blazer1AB
    Sep 1, 2005
    29
    KC
    ok, I just dont wanna completely screw up the timing, i just wanna get the thing to run so i can buy it.
  4. Blazer1AB
    Sep 1, 2005
    29
    KC
    to the top...
  5. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    here is a quick overview
    get the engine to TDC on number one cylinder then remove the distributor, put new one in with rotor pointing to the number one terminal install hook up and then time it with a timing light.
  6. Blazer1AB
    Sep 1, 2005
    29
    KC
    Ok, the "number one terminal" is what the wire plugs into on the cap right? And i read somewhere about the oil pump pin, so does the distributor only go in one way, or do I have to worry about being a couple teeth off or anything?
  7. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you do have to make sure it goes in right you can put it in a few teeth off. Look on the cap it should have the number one marked. put the cap on the distributo and mark on the distributor body where number 1 is then when you install it keep the rotor pointed at that mark
  8. Blazer1AB
    Sep 1, 2005
    29
    KC
    ok, thanks.
  9. Blazer1AB
    Sep 1, 2005
    29
    KC
    If anyone else has any tips/thoughts, please let me know.
