Distributor install tricks????
Discussion in 'The Garage' started by GM Man, Mar 17, 2004.
  1. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Just trying to re-install my distributor but cant get it to drop that last 1/4" in. Any one have ideas on what I can do to get it to slip the rest of the way in?? /forums/images/graemlins/1zhelp.gif
    Already have it up on compression on # 1.
  2. win717
    win717 Registered Member
    Mar 8, 2003
    60
    PA
    sounds like the oil pump is hitting just keep lifting the dist.up a little bit and kinda tap it down it will move the pump around til it drops in the slot on the pump
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    It sounds like you need to line up the slot in the oil pump drive shaft with the bottom of the distributor shaft. Get a big flat head screwdriver and rotate the pump shaft until it lines up with the dist. Once they are lined up, the dist. should drop all the way down. /forums/images/graemlins/waytogo.gif
  4. fjleiter
    fjleiter 1/2 ton status
    Feb 13, 2004
    278
    Palmyra, NY
    If I remember correctly, take a long slotted screwdriver
    and looking down in the hole for the distributor you will see the oil pump shaft (which will be slotted), make sure the slot points to the #5 cylinder and it should drop in
    if your distributor has been aligned properly. May take some minor readjusting but should get you close.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Get the gears lined up to where you want them and if it doesn't just drop in, have someone bump the ignition while you push down slightly on the dist. it will fall right in.
  6. GM Man
    Jan 12, 2003
    549
    Denver CO
    So thats what Im missing, thanks guys!! /forums/images/graemlins/bow.gif
  7. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    just don't drop the screwdriver in there /forums/images/graemlins/doah.gif
  8. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Just turn the engine with a breaker bar on the harmonic balancer, it will drop right in.
