Distributor question...
Discussion in 'The Garage' started by socal chevy, Aug 24, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    I got a 350 motor and I pulled my distributor out to clean the motor, and now it wont go back in... It goes in, but comes short from being "all the way in" about 1/2 an inch. How do I get it in there? Thanks!
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Scan down the page to the post titled "dizzy questions for a 454". Same problem and the answer is in there... :cool1:
  3. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    I did that and it still doesnt go all the way in....
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    You probably didn't put it back in the same spot you pulled it out at... try to take it back out, go over one tooth on the mating gear and drop it in again.
  5. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    it is such a pain in the a$$ its ure oil pump shaft. get a really long screw driver and move it a tiny bit at a time till it drops down all the way. patence is the way grasshopper :D
    and what he said
  6. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    btw why did u take it out for? that would be a last resort in my book. u can get stuff dropping down the hole, pain in the butt to reinstall, and might knock timing off. little late now though :wink1:
  7. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    Because Im a noobie
  8. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i would have to say that the oil pump shaft is lined up with the dizzy.
    somehow i know.......now. :doah:
  9. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i learned when my mallory died and replaced it with stock. i have the money to fix the mallory now- but im not looking forward to do it....so it sits on my work bench :doah:
    when ure done u can do mine :D :D :D
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Drop it in about one tooth or so before the #1 line up area, have someone bump the engine slightly to turn the cam gear, it should drop right in, it's not lining up with the oil pump slot, i do this all the time, just be sure after it drops in, to double check that is lined up to where it's supposed to be when installed.
