Distributor wire?
Discussion in 'The Garage' started by 88K5Jimmy, Oct 17, 2002.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Is there a wire going to or coming from an HEI distributor? If so where does it go/come from? Also, if anyone has a wiring diagram for an 86 gas motor that would be great.
    Ross
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    There is a tan or orange wire that runs to the part of the hei cap that juts outward on the drivers side. That wire goes into the fuseblock. It gives 12 v when the ignition is in the "on" position. There is a three wire plug that runs out of the dist body into the cap itself. If you have a tach..there is another wire ran the same way as the power wire. It is just a signal lead to the tach. From looking striahgt on top of the cap using x-ray vision it looks like this:
    | H P |
    | H |
    | H T |
    H=harness this side is cloest to the dist body
    p=power wire
    t=tach lead
    I think that covers it.
    Blake
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    blake has that one covered.coundn't of done better myself. /forums/images/graemlins/smile.gif
