distributor won't fit in 350. help!
Discussion in 'The Garage' started by vortec, Jun 25, 2006.
  1. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    i finally installed my engine, yesterday. now, i can't get my old distributor all the way in it fit fine in the old 350. about 1.5-2" of shaft still sticking out above manifold, and the bottom of the shaft (outer housing, not the part that turns with the gear), where it widens right above the gear, is where it is apparently hanging up. it has a tiny ring worn around the bottom from me gently turning it around in there, trying to get it to seat. i've never seen a distributor be more than snug on install. were there two different models used in 80-85 (mine is 82), one slightly wider? can i just steel wool (or something) the shaft until it is narrow enough? the difference seems tiny, but i am not about to force it in there. please help! thanks a lot
  2. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    Your distro wont seat inless the pin that drives the oil pump is lined up. It will take some fiddling with at different positions to get it back in. I had to realign the distro on my truck when the PO put it in a tooth off.. Bastard!
  3. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    i got it in. i just steel wooled the part down for a loooong time. fits great now. who the heck knows why it was like that.
  4. 78GMCJIMMY
    78GMCJIMMY 1/2 ton status
    Mar 29, 2003
    135
    Gresham,Oregon
    I second the oil pump driveshaft! The slot in the bottom of the dizzy gear must line up with the oil pump driveshaft!
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    The oil pump will only make it hang up at the last like .25" not 1.5" - 2" like he's saying. Sounds like he was right anyways.
  6. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    yeah, i guess i forgot to mention that i have not installed the new oil pump and shaft yet. that's why i knew that wasn't the issue. thanks anyway, though.
