distributor ???????????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudhog, Sep 7, 2001.
  1. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    what would cause a distributor to make a knocking sound and also when at low rpms to be jurky or cut out but at high rpms be just like normal? i have tried diferent wires cap and rotor any ideas?
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Bushing(s) bad.............had that happen a few years ago.
    Didn't know you had this problemo.............check the rotor if it is wobbling up top you will know it quickly.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    no there is no woble that i can feal i tried to grab it and move it front to back and side to side and it seams tight. anyone have any ideas? it is driving me nuts[​IMG]
  4. dyeager535
    26,975
    Stuck advance weights? Check that the terminals aren't hitting the rotor. If the cap terminals are loose, the inside pieces that conduct to the rotor can and will hit it, and bend them out of the way. You can tighten them up if loose pretty easily.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  5. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    Check your advance weights and springs. You can get a new weight and spring kit for about $5.00. I can't think of much else that would cause it if the bushings are tight.
    <font color=red> Elkboy </font color=red> 82 K5 fuel injected H.O.305, TH350/205, 14bolt/10bolt and 39.5 TSL's.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  7. elkboy
    Aug 18, 2000
    293
    Hillsboro Oregon
    Should be two arms 180 DEG from each other under the rotor. One side of the arm is attached by swivel pins the other side is attached by springs. They controll some of the advance via centrifical force. The more RPM the more advance.Good look, and good bowhunting.
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  10. dyeager535
    26,975
    did you pull the cap and rotor off and observe the two weights? All you do for a "test" is make sure the little bushing they slide on is present and not damaged, and that you can move the weights easily (spring pressure on them) with your finger. Make sure there are two springs as well, maybe one came loose.
    Dorian
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  12. elkboy
    Aug 18, 2000
    293
    Hillsboro Oregon
    A bad vaccum advance will be most noticable under accelleration. A flakey pickup could also be causing you weird problems. You could also slide over to U-pullit and pickup a whole working dist for about $15.00 if you get tired of playing with it [​IMG].
  13. dyeager535
    26,975
    Vac advance is pretty easy to test. Pull off the cap, remove vac hose off carb, and suck on it, watching the rod the vac advance pulls on, move. Once you get it to retract, plug end of hose with tongue, and watch for the rod to move. if it moves, the vac advance is bad. If it holds position for a few seconds, its fine. As to noise, I really doubt thats the problem. replacement may be an idea, or just pull the distributor all the way out, and see if the shaft or gear is shot or worn out.
    Dorian
