distributor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by choper, Jan 12, 2002.
  1. choper
    choper Newbie
    Nov 9, 2001
    3
    What i need to know is it possible to use my distributor with
    computer plug after converting from electric carb to Edelbrock performer carb
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if your distributor doesn't have a vacuum advance on it, you will have to keep the ecm in place and hooked up to the distributor as it controls the timing, the carburetor you took off was also controlled by the ecm so the system isn't going to be working as designed. you would be best to get a vacuum type distributor and go without the ecm
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
  3. choper
    choper Newbie
    Nov 9, 2001
    3
    I have vacuum advance on the distributor but its a 1986 blazer
    that had that electric carb and it had a plug for the computer
    that is in the glove compartment.
  4. dyeager535
    26,975
    if you have vac advance on the dist., its not ECM controlled. Its ESC, which as another post has covered (search for "esc") can be converted to "standard" HEI.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
