distributors?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gotmud77, Jul 19, 2004.
  1. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    Which ones are are the best to run? I was thinking the msd ready to run one. But not to sure if there is one that is better than this. Also i will be changing to tpi so hopefully the new one will work with it also.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    stock one works fine for me, just upgrade the coil.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Don't spend the money on the MSD large cap coil if you are going to swap in TPI. You will need a new dist again. Get yourself a stocker for a reasonable price to put in for now or run what you have. Don't think about spending $$$ on a dist till you are ready for the TPI and then if you still want it get the MSD small cap HEI dist.
    I am running a stock dist with an MSD cap and rotor on my truck with TPI. Works fine. If you feel like it you can throw on a MSD coil, they are $40 for a TPI setup. Wires are a good idea to. They are around $60-80.
    Harley
  4. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Personally I think the MSD is a great distributor. I have the ready to run pro billet, which has the small cap. Don't know how it works with TPI, but it is supposed to be a direct replacement for an HEI distributor.
    For what it's worth, I would stick with an HEI unless you need to replace your distributor for some reason. Or you just really want an MSD.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Stock really work good until higher rpm's , to remedy that you get a new coil . I don't think a truck really needs to see high rpm's anyway , unless you run mud /forums/images/graemlins/k5.gif
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Actually to remedy that you need a new coil and a new high performance module. Both the module and the coil won't keep up with RPMs over 4500 or so very well.
    When you swap in TPI you will swap in a small cap HEI distributor in place of the big cap HEI that was used in carb trucks.
    The small cap HEI is the only way to go with TPI. The new intake plenum takes up alot of room in the back area of the engine and even with the small cap HEI it is really cramped. The big cap HEI will only make the problem worse.
    The small cap HEI also uses a remote coil and coil wire. The high performance coil for the small cap distributor is about 1/2 the price of the MSD coil for the large cap.
    MSD does make replacement small cap HEI's if you want to use the MSD stuff on your motor. It is semi pointless to swap in an MSD distributor if the reason is to run high RPM. TPI runs out of air around 4500-4800 RPM.
    Harley
