Distributors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by deothrwhtmt, Sep 14, 2002.
  1. deothrwhtmt
    deothrwhtmt Registered Member
    Feb 24, 2001
    61
    Maryland
    How much poo am I in for, if I want to change my distributor in my 88K5? Do I need to remove my hood? Should I go with the kind I can just pick up at autozone or something like a Mallory or MSD? Any tips or tricks? Really need help. Thanks in advance, no pun intended.
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    whats wrong with the one in there now?...to tell ya the truth you wont gain much power to the cash outlay...prob not even enough to notice i would just save your cash and keep the stock on in there...i pulled all my msd stuff off and sold it all...it made no difference at all from stock except on start up
  3. deothrwhtmt
    Feb 24, 2001
    61
    Maryland
    Did something really dumb and snapped cap off. The little metal plate the cap was attched to now revolves around the shaft. This type of "variable" timing isnt good. /forums/images/icons/grin.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd grab one out at local salvage yard.
  5. deothrwhtmt
    Feb 24, 2001
    61
    Maryland
    Copy that. I checked around and the yards want just as much as a new one from Autozone or "3 stooges" aka Pep girls. So do I have to do anything crazy to get this thing changed out? Or is it straight up loosening the collar and the hold down? Do I need to take the hood off?
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've never had to take a hood off to change a dist., but I haven't done one on a Blazer.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    No dont pull the hood. Just unplug everything , revove the hold down clamp and pull the dist out.\
    when you pull the dist be sure to mark the position of the rotor and how the dist body sits in the engine. You will want to install the new dist exactly the same way so that things dont get way out of time
    The stock dist on the TBI trucks is a good unit. You really wont gain anything with a performance dist.
    If you want to get a little more power out of the ignition. Just get a good set of wires and the MSD blaster coil .
  8. deothrwhtmt
    Feb 24, 2001
    61
    Maryland
    When you say distributor body, is that the cap or the depth of the shaft? I cant really remember what direction the whole unit was facing I will see what I cando to try and match it up. That metal plate under the cap, or what the cap tightens down to is what has snapped off.
