Ditch that rod yes or no
Discussion in 'The Garage' started by 84 K5 4x4, Dec 1, 2006.
  1. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    does anyone know if that rod that runs from the motor mount to the transfer case on the passenger side is called and if so can you ditch it
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    It is called the Transfer Case Support Strut Rod. I would not ditch it if you plan on keeping the 700/208 combo. It helped reduce the liklihood of craking the aluminum bellhousings on the early 700r4s. Youre gonna have a totally different setup with the 465/205, so its not needed.
  3. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,993
    130
    Keep it.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't have one & haven't for awhile. I got rid of mine cause it wouldn't quite bolt up after the tranny rebuild & tcase rebuild, otherwise I would have kept it.
    Harley
  6. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Keep it!!
  7. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Keep it. I know a guy that says, " Eh, no need!" He's in his 3rd setup.
  8. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I had one on my old 400/205 passengerside bellhouseing to t-case. No problems, It only helps....the stiffy
  9. Slapperbar
    Nov 29, 2005
    2,747
    3
    Stiff is good... for her... no wait... uummmmm.. no, yup it's good.errrrr.
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Keep it and if you've got the ones from your motor mounts to the converter cover, keep them too...and if you haven't got them, get them! Your motor/trans/t-case are mounted in two places longitudenly (is that a word? you know what I mean), apart from the torque of your motor trying to twist the whole assembly like a big carrott about to snap, when you go over any big bumps or get any air that whole assembly will try to flex in the middle when it lands and the trans is only bolted to the motor at the top and sides by 6 comparitivly small bolts.
