Diverside Window Replacement
Discussion in 'The Garage' started by msb350, Dec 15, 2004.
  1. msb350
    msb350 Registered Member
    Jul 6, 2004
    When I purchased my 89 K5 the driverside window was busted out. I got a replacement out of an 85 burb and was woundering the best way to install it. Any help is appreciated. Thanks.
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    Granbury, TX
    with the window fully down:
    you have to pull the interior door panel off, then remove vent window assembly
    then you slide the old window (or bare track in this case) out of the rollers, replace with the new one, and re-assemble
    when putting the new window onto the rollers, you are going to have to play with it to make it fit correctly: raise window to about halfway up, mount onto front roller then lower fully, then slide window forward to get the rear roller in the open end of the track
    this is assuming that nothing is different from my 78
