Divorced 205 transfer case ?'s
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mkmiller, Feb 3, 2003.
  1. mkmiller
    mkmiller 1/2 ton status
    Oct 31, 2001
    306
    Magnolia, Arkansas
    Divorced 205 transfer case ?\'s
    I just bought a divorced NP205 transfer(couldn't pass it up). It's out of a '63 chevy and seems to work fine. Give me some opinions on the pros and cons of the divorced unit. I was planning on keeping it to run behind a Th400 tranny. Also, What are these things going for in your area? No it's not for sale. Like I said I'm looking for PROS and CONS of the thing as this is the first one I found and I know it's stamped 4-20-63 on the case.
    Thanks,
    Matthew
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Re: Divorced 205 transfer case ?\'s
    If it is the case that originally came in the '63, it is a Rockwell T-221, not a 205.
  3. mkmiller
    Oct 31, 2001
    306
    Magnolia, Arkansas
    It came out of a 3/4 ton. It has the small 2-3"diameter plate in the center of the back of the case. I thought only 205's had the plate?
  4. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I originally thought I had an NP205 also, but it turned out to be a Rockwell T221 - a tough tranny but just hard to get parts for. Some like it for the low rear output. Here's a pic.
  5. J.Lance
    J.Lance 1/2 ton status
    Oct 8, 2002
    145
    Arvada, CO
    Like mentioned, if it's an original divorced case, it's a Rockwell. Should be a tag riveted to the top if it is. The tag says Rockwell T-221 and also gives the ratio. I've got a Rockwell married to a 4 spd in my '68 and another one mated to a 3 spd sitting in my driveway. Not sure what there worth but they are a rare find. Just need to find someone looking for one is all. I suppose if you had a long bed you could rig up a dual case set up but might be more trouble than it's worth. I don't recall a 205 being used in any divorced case set up for Chevy. Ford might have used them in the 70's. Maybe someone swapped it in? Clean it up and look for casting numbers and tags. If it's a 205, should say NP on it somewhere.
  6. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    My buddy has a '66 3/4 ton with the divorced Rockwell. His is trashed and he has been looking for a replacement. He can buy the parts needed to fix it, but he is looking at over $500 plus the rebuild (his time.) He has had a very hard time even getting any info on the t-case. If you were closer, he'd probably buy that thing off ya.
  7. mkmiller
    Oct 31, 2001
    306
    Magnolia, Arkansas
    THANKS! The picture Yukon posted does not look like the transfer I have. At the very bottom on the case mine has raised numbers"1.96 to 1 ratio". It has no tag on it, but the back is similiar to the pic, only the center plate looks smaller on mine and the outer plates look bigger. It looks very like the one in my blazer only it's divorced. I'll have to snap a few pics of it tomorrow and try to post them. Could it be out of something else? I know it has the date of 4-20-63 stamped in it but I can't find a GM stamp anywhere?
    Matthew
  8. mkmiller
    Oct 31, 2001
    306
    Magnolia, Arkansas
    I just had to run out and take another look. It is definately a 205. It has an E-brake setup on the rear output shaft as well. I've got to run to work or I'd go take some pics and post em.
  9. 72beater
    72beater 1/2 ton status
    Oct 11, 2002
    224
    Nation\'s Capital
    maybe you could use it in a doubler type setup. just an idea...
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Could have been swapped over from a Dodge or IH. Many of these were remote - although I haven't seen one with a drum brake. Very cool /forums/images/graemlins/thumb.gif
    BTW: The Spicer 23 also ended up in place of some of the divorced Rockwells /forums/images/graemlins/wink.gif
  11. '72brett
    '72brett 1/2 ton status
    Dec 3, 2002
    166
    northwest Iowa
    very interesting thread we have going on here. Sorry I can't post anything about this stuff. I KNOW NOTHING about it. One question I do have.... about how much extra (lost)horse power does it take to run the 205?
  12. mkmiller
    Oct 31, 2001
    306
    Magnolia, Arkansas
    I've got the pics, now I can't post em! Me + computer=Bad Combo. Someone help post 'em? I can email them to ya.
    Thanks,
    Matthew
  13. mkmiller
    Oct 31, 2001
    306
    Magnolia, Arkansas
  14. ChiScouter
    ChiScouter Newbie
    Feb 6, 2003
    Dodge and IH used divorced 205's. Before the 205 IH used a 202 which looked just like a 205, but was around 10 percent larger
  15. Blazer1970
    1,600
    Old Mission, MI
    I have never seen a 202, or any other earlier model New Process case, but I am guessing that the one the mkmiller has is one of these older models. It does not look like a 205, and he said it has a date tag from 1965. I am pretty they didn't start making NP205s until at least 1969.
  16. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Looks like a NP 202 to me . I think the 205 was the replacement for the 202. Look at the cast seal retainers and the cast iron rear cover for the front output shaft.They seem to be strong but I'll bet parts are very scarce.
  17. u2slow
    May 9, 2001
    2,217
    BC Canada
  18. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    That is a COOL looking t/c mount set up !
    What is the difference between the NP 200 and the 202's ?
    They seem to look very similar , the only ones I have seen in person I have not had time to really look them over , other than that I have only seen pictures or drawings.
