divorced case, is this a crazy idea??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Sep 4, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    you go up to like 6"-8" of lift you have front driveline problems right? well would it be crazy to set up like a divorce mounted doubler in a suburban? the rear line is long enough to make it possible and it would make the front longer eliminating some of the problems, and with it divorced you could clock it up into the frame with out special adapters.
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I know they make divorced 205's, you would just have to find one. But that does sound like a pretty cool idea if you have the length like you do. I just dont know if they make a divorced 203 for the front. Maybe someone can answer that.
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Both ford and dodge use divorced tc's. In the F250 ford went from a divorced to a married tc when they went from the high rider to the low rider around '78 or so.
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Ford used a divored '203 for awhile.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Of course, clocking it up into the frame worsens the front driveshaft angle again. Of course, a sub is so long that it runs the quarter-mile without the rear wheels crossing the light tree. So you could probably center the T-case between the two axles and run the same driveshaft front and rear. Only one spare and the same angles front and back.
  6. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I know a guy who has a manual transmission and a divorced t-case out of a really old (like mid 60's) chevy truck. I could ask him if he wanted to part with them if you want them (although they are super heavy and in Michigan). I think a divorced t-case setup in a burban would be the $hit... The guy who has the tranny/divorced tcase said that those two units will take some punishment.
  7. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
    I didnt put it together but my divorced setup has been working great on my longbed. It is dropped about 3 inches. I think it would really help if you were tryin to install a really tall lift.
  8. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    See if you can clock your existing T-Case to make sure you have enough drive shaft clearance, then you have multiple low range capabilities /forums/images/icons/grin.gif (Cheap "Doubler") I am probably going to go that route on my Crew Cab, but I am going to use a driver's side drop Dana 60 and divorced 205. (Because I can get them CHEAP!) Always a deciding factor.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah, great, you can lower your transfer case and gain back driveline angle with a divorced setup, but you give up breakover angle and major ground clearance in doing so.
    I personally have a 6" lift with a stock front driveshaft and it works fine. My front driveshaft is extremely short too with the 4 speed/205 combo.
  10. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    You couled probably fab something up without the help of ORD's doubler...Just get your hands on a divorce mounted 205 w/ passenger side drop (so Early Chevy or Dodge) and fab up a way to hold it between the frame rails...The just run a real short shaft between you current 205 and the divorced case...the fab up a shifter...Damn, If I had that kind of wheelbase to play with, I would be in the garage now /forums/images/icons/wink.gif
    Start looking for a divorced t-case with passenger side drop...
    Chris
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Or...get a cheap, high-pinion '60 from an early Ford and a Divorced transfer and have your pumpkin on the driver's side....
  12. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Maybe I could talk to John Marlin about doing a double 205 setup. He's the guy who invented the Marlin crawler. I know where his shop is here in Fresno.
    Y'all are givin me thoughts now....... /forums/images/icons/grin.gif
  13. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    International trucks used the divorced 205 with a really slick crossmember that is easily adaptable to a Chevy frame. I ran one in a 55 Chevy converted to 4WD with an old NV 5 spd trans out of a school bus. Worked great and was easier to service than the married T-case.
  14. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    I have a 208 turned upside down with slip yoke, a really short driveshaft and a divorced 205 with the rear clocked down to make the rear drivesaft angles better. The rear is about 32" but the angles are something like 14 degrees.
    The front driveshaft was "a little" more complicated...
    It is 3-piece, 4 u-joints, 2 slipyokes and 2 carrier bearings! Propably there is something not needed but none of the u-joints have more than 14 degrees at rest and nothing is hanging under the frame when you looke from the side. But I only have maybe 2-3" of lift so it helps ofcourse.
  15. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i am going to do it in my blazer. the rear is long enough for me, i feel anyway. i can have one spare driveshaft as well.
    with some mods anyway. you could also use a case OTHER than a 205. might ahve to have some custom work done. but it is possible.
    i have been trying to get Or2play to see this also. he has LOTs of driveline in the rear of his burban... bout the same as you i am sure.. he he...
    but anyway.. he just wants the simple way out. you do have 2 more U-joints and a small shaft to buy, but oh well.
    grant
  16. muddysub
    Jun 23, 2001
    10,451
    489
    ok how about this: my th400 a klune-v goliath 3.5:1 or so, about 10"-12" of shaft and then a divorced 205. or even a married 205 since the klune-v would push it back some.
  17. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i still like the idea of = length shafts...
    it just makes life so much easier.
    and the idea of flatening out the 205 so your angles are the same or very close.
    grant
