divorced choke vaccum line Q
Discussion in 'The Garage' started by R77K10, Apr 27, 2006.
  1. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    ok on the 70s (1705 and under) series quadrajets with the divorced choke, AKA 4MV carbs- does anyone know what type of source the long metal tube out the passenger side of the carb is- where the choke assembly step cam parts are located on the side of the carb
    anyone happen to know what GM originally used the port for/what it was intended for ?
    what do you use it for ?
    thanks
  2. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    ttt
    thanks
  3. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
  4. 78GMCJIMMY
    78GMCJIMMY 1/2 ton status
    Mar 29, 2003
    135
    Gresham,Oregon
    Well on my jimmy i have that port hooked up to the defroster/vent vacuum supply canister on the passenger side. Hope this helps. oh yeah I believe if you have a stock air cleaner the vacuum line for the air vent for warm up goes there? Later
  5. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    sounds like it is full manifold vacuum then
    right ?
    thanks
