Divorced Double Case ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by parts bitch, Dec 31, 2004.
  1. parts bitch
    parts bitch Registered Member
    Jun 17, 2004
    27
    Westminster MD
    Ok... I am Starting on a project with a Box Truck Diesel small inline six and Auto Tranny
    Since i already have it.
    I want to Run a Divorced Case off the back of it.
    but a 205 isnt Low enough.
    and i dont want to run divorced case into a divorced case if i can keep from adding the extra length.
    Does anyone Make a Doubler for a divorced case ?
    or is there a way i can make it ?
    or something.
    Ideas ?
    HELP !!!!!!!!!!!!!!!
    :dunno: :hack: :weld:
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You can use a divorced 203 range box, normal doubler adapter, and normal 205.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you're not short on money, Klune V makes one.
    It'll run you around 2K.
  4. parts bitch
    Jun 17, 2004
    27
    Westminster MD
    If your gonna spend $2k, Why not run an Atlas then ?
    Trying to spend quite a bit less. :cool1:
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well I am not spending 2K just yet, but when you get the klune or a doubler you have choices of 4 gear ratios not 2: one deep and one stock.
    You get Hi, HI, Low LOW hi Low and LOW hi with the low in each being different you get 4 gear ratios.
    :grin:
  6. parts bitch
    Jun 17, 2004
    27
    Westminster MD
    True. But. i hardly ever take my CJ out of LOW as it is.
    but its a NV4500 and D300 and rockwells. = 100-to-1
    with rockwells again (99% chance) and this auto trans 1st Gear being 3.05 and Converter making it 6ish
    - Atlas 3.8 it would be. 150-to-1 about.
    - just a 205 would be 75-to-1
    - Double Case - Back up to 140-to-1
    Don't you need to put the Klune between tranny and t-case ?
    and that woudnt work with a 2wd trans right ?
  7. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Correct, the Klune would go between the tranny and Tcase.
    You need what the other guy mentioned. A divorced NP203 range box with any NP205 mated to it. The divorced 203 could go on a jack shaft off the 2wd auto. You better have 115+ "s of wheelbase though
    I have 107"s with a manual (sm420) custom 3" adaptor, NP203 range box, Jeds doubler, NP205 in my jeep and it leaves a 21" driveshaft. Add the auto wich has to be a foot longer than a 420 (11"s) and the jack shaft and you got no driveshaft left if you are under 105"s. You mentioned a CJ, that will not work without a real long wheelbase extension.
  8. parts bitch
    Jun 17, 2004
    27
    Westminster MD
    My CJ in Current Config. is 114" wb.
    And with Rockwells a 21" Driveshaft is Pleanty.
    Mine is currently about 18" with Tons of Travel left.
    But i am going to building Tube Buggy. So i can make it whatever i want.
    I am planning on the 110"-115" though.
    with the Motor WAY forward in the Chassis and the Radiator in the Rear.
    So does anyone have the 203 RB or the 205 ? :D
  9. parts bitch
    Jun 17, 2004
    27
    Westminster MD
    Current Picture.
  10. 6.2puller
    Jul 8, 2004
    569
    New England
    Yah, I looked at your pics in your sig after I posted. Looks like you know about wheelbase stretching. Hard to tell a dreamer from someone who knows what there talking about on these forums.
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well if you go on the Klune V website and check, they have a setup for a divorced case.
    It will work with a 2wd tranny, it bolts up to a divorced Tcase and has a cover and a yoke on the front.
    just a couple hundred more.
    Klune V is about $1750 plus the adapter to make it divorced is total of about $2000.
    :D
    Anyways, good luck finding a divorced 203, I know they are out there, I was supposed to get one but still didn't get any response back from the guy in a few months.
