Divorced Doubler
Discussion in 'OffRoad Design' started by rodzzilla, Feb 1, 2002.
  1. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    How close is the Divorced Doubler to seeing the light of day? I have a line on a divorced 205 along with a F@rd D60. (The price is just about right) Would a person be able to drill & tap the end of the 203 output to accept a bolt on TH400 yoke? Or does there need to be a seal after the 203 box?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We have the parts on the shelf to build one anytime you want it. We use a bolt on yoke like a 203 or 205.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  3. rodzzilla
    953
    Grinnell, IA
    What is the price on the Divorced set up? Need to start budgeting funds. Thanks.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    $800, you supply the yoke. Or if you like we can too but it's not part of the kit since there's so much variation in what people want to use on the driveshaft.
    SW-ORD
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Divorced doubler--now you guys are talking! No more driveline angle problems!
    Tim
  6. ScoutII
    ScoutII Registered Member
    Sep 11, 2001
    9
    Stephen,
    I'm trying to visualize this divorced doubler. Would you please send me a photo of this to:
    afm19@pipeline.com
    thanking you in advance
    denny
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I don't have a picture, we don't have one on the shelf and don't have pics of the past adapters. Imagine a yoke sticking out the back of the adapter housing and you've pretty much got it covered. If you need more info on it let me know, I just don't have a pic at this point.
    SW-ORD
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    not a bad idea rob. isnt the 205 off a dodge right hand drop?
    cus then i am sure i can find one out here for you.
    lets see.
    divorced adaptor 800
    dodge div. 205 ~150
    drive shafts center ~150
    rear ~75 cut mine down as needed
    front ~125 lengthen mine as needed
    ~ 1300
    that is about the same as finding a chevy th400 np 205
    but a lot less time consuming
    Grant
  9. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    okay i haven't gotten into the Transfer Cases mucho so could you bear with me, and explain a Divorced Transfer Case please??? thanks alot, because if it solves driveline angle i would be very mucho interested!!!! thanks a lot
    Ck1500
  10. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    the divorced 205 was in ford and if i remember right dodges.
    take a 2wd trany and a divorced t-case. put a drive line in the middle and 2 more for the axles.
    that is what a divorced doubles it.
    Grant
  11. Ck1500
    Feb 8, 2001
    198
    Burton, Michigan
    wow thanks!!! that soundz very interesting, "sorry for the DUMB question" i just haven't gotten to that phase of operation BLAZER OUTTA MONEY /forums/images/icons/smile.gif jk
    thanks again
    Ck1500
  12. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    There are couple ways to go in a divorced application.
    one is marry the 203 gearbox to the trans and run the 205 as a divorced unit. Goes like this:
    trans/203 -- driveshaft -- 205 -- driveshafts to the axles.
    another is to marry the 203 and 205 like a normal married Doubler but mount them divorced using a divorced ford NP203 input gear.
    Like so:
    trans -- driveshaft -- 203 gearbox / married 205 -- driveshafts to axles.
    The most cumbersome way is to use the divorced ford 203 with a divorced doubler kit. Then you get:
    trans -- driveshaft -- 203 -- driveshaft -- 205 -- driveshafts to each axle.
    All in all the divorced stuff isn't very popular since it takes up so much space but it can work well for some.
