Divorced NP205 For Sale, $200
Discussion in 'Pacific Region' started by ljbear, Apr 30, 2004.
  1. ljbear
    ljbear Registered Member
    Mar 24, 2004
    92
    Grass Valley, CA
    A friend has a Divorced NP205 transfer case for sale. It came from a Dodge truck, all drives are on the correct side for GMs. He is asking $200. It's located in Olympia Washington and he would prefer to have it picked up, but probably would ship. If you are interested let me know, I'll give you his number so you can deal directly with him.
  2. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    do you know if the shaft would mate to the th350 without major modiifications?>
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    It has a ujoint yoke for an input and no bolt pattern to attach to an adapter. In a longbed pickup you could use a 2wd tranny with this divorced tcase to put the tcase in the middle with equal length driveshafts. In a blazer however you would have length issues as the rear driveline is already short enough.
  4. ljbear
    Mar 24, 2004
    92
    Grass Valley, CA
    I justtalked to the owner, and as Kenny mentioned it has the u-joint input. He also has the short driveshaft that will tie it to the transmission. I think it could be used in a blazer, but more appropriate for a SWB or LWB truck. I've never looked under a 69 blazer, but they probably had a divorced T/C like the early 4x4 GMs had, so it should work.
  5. wtfbigtruck
    wtfbigtruck Newbie
    May 15, 2010
    hellertown pa
    np205 divorced tcase
    is this unit still for sale? Thanks brian if so you can call me.
    cell
    (484) 241-5579
    It has a ujoint yoke for an input and no bolt pattern to attach to an adapter. In a longbed pickup you could use a 2wd tranny with this divorced tcase to put the tcase in the middle with equal length driveshafts. In a blazer however you would have length issues as the rear driveline is already short enough.[/quote]
