Divorced t-case question
Discussion in 'The Garage' started by Russell, Feb 26, 2005.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Hey guys!
    I picked up a divorced transfer case today, but I need some help identifying it. The seller claims it is a 205, but it seems rather small to be... It has an aluminum housing, and I am able to pick it up myself. It has 29 splines behind the u-joint knuckles. Wouldn't a 205 be rather heavy? He had it installed in his S-15 350 powered Jimmy, and bought it off someone else prior to that. It has a u-joint knuckle input and front output, with a slip rear output. I am on the road right now (wireless internet, father is driving, lol) so I cannot get you guys pictures till later on tonight. I bought it becuase it was a fairly long drive down, and if it isn't a 205, or something tough enough for my K25, I will ship it back to him collect while demanding a refund.
    Anyone have any ideas?
  2. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    I can't quite guess what it would be (Ford Borg Warner?), but anything aluminum or 29 spline at the output is NOT a NP205.
  3. Russell
    Jun 23, 2000
    7,923
    333
    I does have a passenger side drop, so it has gotta be either Chevy, Dodge or IH...
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Divorced NP205's did not have slip yokes either...sounds like you've been had.
    Being able to pick up a 205 is a relative term. I can pick up and carry one no problem.
  5. Russell
    Jun 23, 2000
    7,923
    333
    Hmmm... I guess we will just have to identify it, and figure out if it is going to be tough enough to stand up to a fairly stout 355. If not, I know where the seller lives, and I can get my refund either way. Its a good chance he may have just been ignorant to what it actually was.
  6. Russell
    Jun 23, 2000
    7,923
    333
    Ok, now that I am at home, I see it is an NP241. I guess its going back to the PO...
  7. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    Bearing in mind those NP241's can take 5500 ft-lbs of input torque...you might want to keep it? they have better low range, the only think to be mindful of is making sure nothing can contact the case itself, as they can crack easily from a rock impact.
    I'd run it.
  8. Russell
    Jun 23, 2000
    7,923
    333
    This truck won't be offroaded often... Its being built to pull, not play.
    How will it hold up with about 12 000 lbs behind it?
  9. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I don't believe any manufacturer ever used a divorced NP241.
  10. Russell
    Jun 23, 2000
    7,923
    333
    241 was a typo -- I meant 231
    Will an NP 231 bolt to an NV4500?
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The GM 231 is 5-bolt. Nv4500 (and just about everything else) is 6-bolt.
    All it would fit is a TH700 (with the S10 adapter) or a Getrag/NV3500 (S10 version).
