Divorced T-Case
Discussion in 'The Garage' started by jakt, Mar 25, 2005.
  1. jakt
    jakt Registered Member
    Nov 26, 2004
    8
    Peoria, Arizona
    Whats the difference between a divorced T-Case and one that isnt? Quality of life, maybe? Seriously though, I have been wondering.
    Dan
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    A divorced case means that it mounts on it's own crossmember and is connected to a 2wd style transmission with a short drivshaft. A married t-case means it bolts directly to the transmission (adapter). There are advantages and disadvantages to each, depending on what you are looking to do with your truck.
  3. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    if you mount it directly in the middle of axles and get the same yokes for tcase and axles you only need 1 spare drive shaft . because thay are the same length. and if you want a different axle than factory style, such as ford in a dodge or gm , or vise versa. or a tranny that is only a 2x4 tranny and never came with a married tcase.
  4. jakt
    Nov 26, 2004
    8
    Peoria, Arizona
    beautiful, thank you. I feel enlightened.
  5. divorced
    Jul 20, 2004
    5,115
    I like mine because I can swap to almost any transmission without having to have the right input/output shafts, adapters, front and rear driveshafts lengthened or shortened, etc... and I think it looks cool.
  6. sweetk30
    Nov 1, 2004
    25,547
    542
    yep i have a dodge tcase thats going in my crew cab when i make it 4x4. so that it will help with drive shaft angles also.
  7. jakt
    Nov 26, 2004
    8
    Peoria, Arizona
    so for ease of interchangeability, divorced is the way to go? Not a bad idea. A divorced setup makes for a higher chance of something breaking, right? More U joints and all.
  8. sweetk30
    Nov 1, 2004
    25,547
    542
    if you want a divorced tcase then find a dodge or a international truck. thay used them and were pass side drop. and in my opinon the lack of a c/v joint setup would make it stronger. and as long as you use 1 ton joints then you will not need to worry much.
  9. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    I take you have to get different shifters for a divorced setup dont you? Although I guess it would be kinda cool to have the T case lever right by my seat though ;P
  10. gstuck3
    gstuck3 Registered Member
    Mar 15, 2005
    51
    Twentynine Palms, CA
    Early Chevy's had them too. My 66 K20 has a Divorced Rockwell T221.
  11. sweetk30
    Nov 1, 2004
    25,547
    542
    yes but the parts are much easyer to find for the 205. but the rockwell 221 is strong also.
  12. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Dodge M37 military trucks and Kaiser M715 had the divorced NP200, which is basically a divorced NP205. I think the yokes on the NP200 are about a 1350 size. You can pick an NP200 up for a $100.
  13. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    The NP200 in the Dodge and Jeep military trucks is pretty sweet, it has a 2nd rear output with a parking brake drum attached.
    if you really want beef, get a NP201 (40's, 50's, early 60's) or a NP202 (60's) from an International (and maybe some dodges too). They make the 205 look small.
    the rockwell is a good tcase, but watch it for leaks. there is also a bigger version of it, the T223, that came in medium duty trucks.
