divorced unit
Discussion in 'OffRoad Design' started by **DONOTDELETE**, Jan 19, 2001.
    I have a divorced 205 from a dodge and a 203 from a 350 chevy tranny. Is it possible to create a divorced crawler with these parts? Will I need anything more or different? thanks
  1. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    This kind of depends on what transmission you have. The best way to do a divorced Doubler is to mount both cases together and divorce them from the trans. In that case you would need a married version of the 205, or machine yours to be a married version.
    Ford used a divorced 203 in the late 70's, so you could use an input gear from one of those cases, or figure out another way to hook a driveshaft up to that female input gear in the 203.
    We have had some interest in putting a yoke on the back of the 203 gearbox and will probably look into that later this year, and at that point if you had a 203 married to the trans, you could divorce the 205 and be done.
    Hope this helps, the options are kind of confusing at first!
    Making the world better, one truck at a time.
    SW-ORD
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Stephen, I was hoping you would say that...regarding the install of a yoke on the back of a 203 range box, thus allow a divorced 205 to be mounted further back to give guys like me with 13" of National spring lift on a 129" wheelbase Suburban ample front driveshaft without having to go with the $850 80 degree front shaft. I'd much rather spend money on a doubler which would also solve my front driveshaft problem!!
    ken
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    May have to consider it more seriously then!
    SW-ORD
