dixie 28 mt gear reduction starter
Discussion in '1982-Present GM Diesel' started by KRUM, Jun 5, 2003.
  1. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    ok i bought one and i seem to be having shim problems i put in the shim that came with it but it doesn't seem to be meshing with the flexplate. i can hear the starter solonoid
    engage but it just clunks and doesn't turn over.i can manually turn the engine by hand and it seens to mess but it won't start again after i turn it off.
    any ideas?its a 6.2-T400 combo
    thanks,
    Jerry
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    Have you tried it without the shim? I dont have one on mine and i get proper engagement. Might give it a try.
  3. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    do you have the dixie 28mt? and how fast does yours turn? i have dual opima red tops and they are fully charged so juice is not my problem
    thanks,
    Jerry
  4. rugger03
    May 14, 2000
    829
    around
    I dont have a dixie starter but i do have a 28mt. Shims do not have to be used in all applicatons. You can also get different thickness of shims. The clunk you here can be the starter pinion making contact with the fly wheel , i would try it with out the shims to see if that helps. why did you replace your old starter. My starter turns much faster than the regular 6.2 starter.
  5. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    my brushes were worn out i'll try the shim thing and see whas going on,but the starter came with the shim and it said i was sopposed to use it.
    thanks,
    Jerry
